JThiessen
JThiessen's Avatar
02.09.2009, 09:08 AM
Originally Posted by rabosi View Post
You can make the hard case work. I use a hard case that's 45mm tall (2s 5000mah). The battery box is long enough that you can set the battery back a little which will give enough room to route the wires. I think the design on the battery box could have been better though. I dremeled mine a bit but it's not necessary to fit the hard case.
I'm sure I could make it work, but if you had the choice, would you choose that style again for this truck?
BitHed
02.09.2009, 12:14 PM
...thats intersting to know about the battery boxes..I was going to grab some butI dont think I will bother now...Sounds like I can make something just as crappy :D
rabosi
02.09.2009, 12:59 PM
I didn't buy the hard cases for this vehicle I already had them on hand. I think I made it seem difficult but hard case should fit without too much trouble. If you keep the height to about 45mm max then you'll have enough room to route the wires for the ones that connect to the top of the case. This is what I have http://rcbuy.vstore.ca/product_info....cName/74v-lipo.
Overall I think batts with wiring that's flush to the top such as neu, polyquest (and mike's brand looks flush too) may work better for wire routing.http://www.rc-monster.com/proddetail.php?prod=neu25c4s5000car
