You can make the hard case work. I use a hard case that's 45mm tall (2s 5000mah). The battery box is long enough that you can set the battery back a little which will give enough room to route the wires. I think the design on the battery box could have been better though. I dremeled mine a bit but it's not necessary to fit the hard case.
