Unsullied_Spy
Unsullied_Spy's Avatar
02.12.2009, 01:04 AM
Ummm it's the same as a Rustler/Pede/Bandit. So it will handle power just like they do; which is very well, if you set it up properly.
I'm aware of that, and the Rustler diff will come apart under enough power...especially if you launch it hard. Usually the first thing to happen is the output gears shear, but I've had the pin mounts develop slack and then it tears itself apart. Traxxas really needs to put a spider diff in these.
