What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.12.2009, 01:13 AM
Well, my Ruster's diff has held up to 4s and a 1940/7 pretty well. I agree; a spider diff would be soooo nice. Though the diff case is so small I wonder if the spider gears that would fit would actually be any stronger.
02.12.2009, 01:45 AM
If used for speed run the starting load would not be that great. I am not going to drag it, just do some top speed runs! I am more interested in the aerodymanics of the body... Not the best choice but it does look cool!
I need to get my other speed vehicles going again, then branch out after some success!
E-sav
02.12.2009, 07:17 AM
On flat pavement this will not flip, even at WOT, due to air flow. If there is uneven pavement and the front gets lifted slightly it will take off like no ones business. On a big, wide open, smooth car park I can do full throttle runs all day without flipping. If I try the same on the road outside my house I'll get to 3/4 throttle and it'll hit something, lift the front and flip so violently it'll do a full backflip before hitting the ground again.
I run diff lock grease in the rear of this, as I have heard about the weakness in the planetary gears of the VXL diff. Haven't had it let go yet but when I finally get a decent controller and motor and up the voltage i got a feeling it will.
My theory is that the Slash should be better for speed runs when correctly set up, what with the extra length. Bit more stability at speed. It's just reigning in the shonky aerodynamics of all the bodies produced for it.
Check your right-rear spring retainer (the piece on the bottom that holds the spring in), looks like it's not seated properly.
The shock shafts are massacred. Apparently running a stiff setup with heavy oil isn't good for them.
When I get a new body I'll cut it longer, and leave the sides longer too. I also want to drop the suspension even more by fitting shorter shocks. The closer to the ground it is, the better the aero will be I guess. I think it would handle a serious lick if air couldn't get underneath it so easy. I was also wondering about bolting a lip across the front to encourage some downforce.
E-sav
02.12.2009, 07:30 AM
Of course, the other option is one of these:
http://www.thundertechracing.com/outlaw2.htm
Looks rather cool and drops everything low. Also stops the braces from hanging up on stuff when you are running a low setup.
02.12.2009, 11:58 AM
I do like the thundertech chassis. I have one for a pede project and it is quite nice.
as far as lowering and limiting the stock suspension on the slash, a decent pair of on road car shocks (not nitro 4 tec shocks, they suck) would limit movement and allow for a really slammed stance...
I am looking for some beadlocks as we speak... Time for me to start another new project!
E-sav
02.12.2009, 06:57 PM
Hmmm the Epic's are good, but I'm considering getting some STRC alloy rings to go on them. They are a mm thicker for a tighter grip and much lighter. Plus you can get them in Monster green lol.
02.12.2009, 07:45 PM
Good to know. Are the strc rings specific to the epics, or are they the same as a axial 2.2 ring?
