Shark413
Shark413's Avatar
02.12.2009, 02:43 AM
One thing to keep in mind for those thinking about the Losi Smart Diff, I am running it in the center but I ordered a front diff. The reason is if you order a center Smart diff you get a 48T sput that can't be used in the 8ight-E. With the Losi Smart front diff I removed the ring gear (which can be used in the front as a spare) and replaced it with the Losi plastic 45T spur. The only difference is you won't have the brake flats on the outdrives but I don't care because I am running motor brake.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
