sikeston34m
sikeston34m's Avatar
02.20.2009, 06:56 PM
Thank you guys! I'll definately check into the different choices.
I do have several motors to rebuild.
If anyone is interested in a AXI 4120 or AXI 4130 in just about any wind. I will have these rolling off really soon. Just pm me with your needs.
Has anyone ever seen a Pletty Maxx Rotor with the kevlar removed?
The Pletty Max is a 4 pole motor using 12 magnets that are 5mm wide, 30mm long and each is about 1.5mm thick. Pole configuration is NNN-SSS-NNN-SSS, making it a 4 pole motor. I'm thinking about replacing these magnets with some N50 magnets. Then replacing the Kevlar Wrap.
squeeforever
squeeforever's Avatar
02.20.2009, 11:59 PM
Think it would be possible to reconfigure the magnets it has in a NN-SS-NN-SS-NN-SS to make it a 6 pole motor? Or maybe make it a 2 pole?
sikeston34m
02.21.2009, 11:36 AM
Yes, but that would require changing the winding configuration also.
I'll go back as a 4 pole since the winding I have is good.
I wonder what strength the magnets are in a Pletty from the factory? I've read several places about demagnetized rotors.
Lonewolf039
Lonewolf039's Avatar
02.28.2009, 01:55 AM
When I cracked the rotor on my motor, I tried JB weld, and it did not hold. I used isopropal alcohol to clean everything really good and wrapped the rotor in kevlar, but no luck.
I tried a bunch of different glues, even red locktight, but eventually shorted out the windings so I now have a nice paperweight
