George16
Supermaxx
George16's Avatar
02.20.2009, 07:15 PM
Originally Posted by Overkill View Post
Hi all
Having a great read through all forums for lots of info on the 8-T brushless setups, and threads like this have been incredibly valuable to me. If you don't mind me jumping in and asking a question on shocks as there has been a couple of pic in here that show what my question is about.......
What is a great spring combination you can use on the 8-T without using/adjusting the preload for the stock springs on a BL setup? I have read that you can use the rear springs up front but I have not read how well it worked. Any help would be appreciated, so far choosing the MMM combo was due to reading threads on RCM so hoping you guys can sort me out on the spring combos
Welcome to RCMonster Josh . Sorry , can't help you with the springs since I don't own an 8T.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
02.20.2009, 07:22 PM
Cheers Lito, you showed me the way and it has been a great place for info that is for sure.
By the way.....Steeni and himalaya they are two great looking setups
I like it.......I LIKE IT ALOT!!!!!!
