Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
02.21.2009, 04:24 PM
Originally Posted by js058515 View Post
I have also used White rear springs in front and Purple in back. Purple was a little stiff for the rear, but White fronts were similar to the Black fronts except the shock collars barely needed any adjustments. Hope that helps some.
Legend!!!!! That's what I was wanting to hear. I also have the race roller and may just get the rear shock kit and have a play, starting with information given by yourself. I have also read that the rear grey springs work well up front, but that was the only one I could find and they did not state what batts they where using, or what motor.
Are you able to give details of your setup please? Mine is the 1.0 RR with Losi conversion kit, MMM 2200Kv Combo and a Zippy-H Lipo weighing in at approx 629grams (22.2 ounces). Once they all arrive, I'll get pics in my own thread and try different spings and weights that I will hopefully find other guys/gals using. There has to be one that will suit my style
I like it.......I LIKE IT ALOT!!!!!!
