entjoles
02.21.2009, 12:29 PM
here it is , thanks to RCM for a great product , the only issue i have with this build is the motor , its very tight , the mesh is purfect but i can spin the front tires and the rears will spin as well and the motor wont move , those magnets are strong
Chassis = ***** 5 Stars
i also had to use the 44t spur , the 46t plastic i had seemed to rub , and i know the diff was a little wet when i tested the motor so i made a mess ;)
geared 14/44 on 4s for about 38.5 mph
i used the center diff plate i made as i didnt want to paint Mikes
i will also shorten the wires once i get a good soldering station
thanks again RCM, on with the pics
