rchippie
rchippie's Avatar
12.05.2005, 11:59 AM
Dafni in the instructions listed on the strobe site. He says wash out the grease & do not oill at all. I also found out you have to grind the pin down on the outside drive plate so the sprong does not get stuck on the plate. It must be smootharound the little pin. Also your supposed to shim the bearing on each side . So the bearing is centered as much as possible in the stobe adapter.
REAL MEN RUN BRUSHLESS
