Finnster
KillaHurtz
Finnster's Avatar
02.24.2009, 09:34 AM
How about these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEC1&P=7
No info about offset though...
These list a 20mm of set, but it looks like that is from the front, not the rear???
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEE1&P=7
The first ones are what I plan to run when I go to replace the Terrapins on my Savage now w/ 40s. If you want 17mm hex on 40 rims the choices are really limited. I think they are a std 1/2" offset.
If you want more offset, you could always try using the XL axles which have ~+12mm of width per side. If you have a std Sav X, you would have to upgrade to the Super HD diff output cup and XL/Flux axles tho. Also, if you have the hex hub conversion set, Ofna extended hex hubs for the Hyper series could work possibly. They offer upto +12mm as well.
