Dead mamba max esc ?
Jason
Dead mamba max esc ? - 02.27.2009, 01:32 AM
I was overheated my motor and my mamba max esc today both over 200f + and now when I try it it seem to cogging alot when I push on the gas throttle and when I run it for maybe only 5 sec the esc get hot very very fast for nothing ... but not the motor or the batteries ...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.27.2009, 01:56 AM
If the motor got that hot, then the magnets inside it probably lost their strength. When this happens, the motor basically becomes a short circuit. The MM got hot because it was sending power into this short circuit. I don't know if CC will cover damage due to over-heating. Try running another similar motor in the vehicle (if you have another motor...) and see if the MM still operates correctly. If it does, then I would just bite the bullet and pick up a new motor.
George16
Supermaxx
George16's Avatar
02.27.2009, 01:57 AM
You probably demagged your motor. What's your setup?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Jason
02.27.2009, 02:18 AM
it is my 1/8 kyosho st-r truggy.
specs :
mamba max esc bec disabled I was using 4 AA rechargeable for now..
kd36 7xl motor ( 2380kv ).
4s lipo 15c 6400mah.
50t spur.
13t pinion.
What's_nitro?
02.27.2009, 02:22 AM
It seems like a stable setup. Not over geared, and no off-the-wall motor RPM. Though, I am not the "truggy master" on this forum. Do you race with this truck? How's the drive train as far as binding? The motor was somehow overloaded and that made everything heat up. Any rocks in the spur?
Jason
02.27.2009, 02:25 AM
no I dont really know why is heating up I buyed it from someone who have used it only 2 times.. runned it on 12 cells and still heating alot but not like today when I was received my 4s lipo it have going over 200f +
Jason
02.27.2009, 02:28 AM
and no I dont racing only playing into my yard.
George16
Supermaxx
George16's Avatar
If it was heating up with the NiMH and then turn to worse with the lipos, I guess the motor was already shot before you even used it.
Revo with OS .18TZ
Jason
02.27.2009, 02:30 AM
maybe
for now someone want to sell me this motor for cheap :
http://holmeshobbies.com/product.php...3&cat=3&page=1
do you think it can do the job for awhile ?
What's_nitro?
02.27.2009, 02:33 AM
^^ What he said. If it got hot running NiMHs, it was probably shot before HE got it... Do you know what the previous owner was running?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.27.2009, 08:44 AM
You also stated that you use it in your yard. Might be hard to beleive but grass put a huge amount of stress on the electronics. Also the RPM's are a touch on the high side for a truggy, IMO you should have about 2000kv on 4s. My suggestion is to def bite the bullet on the motor. Spend a little more and buy a Medusa or the CC/neu from Mike $140 or less depending on what you choose. The MM should still be fine but don't keep trying to use it with that motor!
Jason
02.27.2009, 09:25 AM
it is snowy there not grass
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.27.2009, 09:47 AM
Sorry, never know these days, week and a half ago all the snow here was almost gone, a week ago we got a foot, now it's just about gone again. Snow can impose a lot of load too though, esspecially if it is slushy and sticks to the tires and chassis. Either way my bet is your motor is toast and you should upgrade to a quality motor now.
Jason
03.01.2009, 02:01 PM
since my KB36-7XL was dead ( overheating ) here is my new setup :
Motor : Neu 1515/1.5D/F 2700kv ( 5mm Shaft )
Speed : Mamba Max 1/0 ESC ( Bec Disabled )
Battery : TrueRC 14.8V 6400mAh 15C 4S2P ( 96A Cont. 128A Burst. )
Gearing : 50t Spur - 13 Pinion.
how do the runtime would be on this ? and all would run perfect and cooler no overheating problems ?
03.01.2009, 04:13 PM
Personally I think that is too much of a motor for a poor MM and a 96amp continuous battery... I would look at a 1Y (maybe castle variety) from Mike
