03.09.2009, 05:23 PM
Hey Tim, had a look at the manuals, and the XL rear center shaft is 142mm long, while the X rear center is 84mm long. The wheels shafts for both are 123mm long, but the XL is 1mm thick vs 9mm thick on the X. So the rear driveshaft is around 2.2" longer on the XL. According to the Savage 5t info they added 2.2" to the length of the XL to get the correct wheelbase for the Baja 5t body. Since the front driveshaft on the xl is 78mm long, going to a XL rear center shaft would give the required 2.2" of addl wheelbase. So it appears that the Savage 5t has 2 142mm long shafts (hpi p/n 86054) as center driveshafts, and the tranny must be in the center of the chassis.
Wheelbase on the XL is listed as 395mm, so adding 2.2" to that would be 55.8mm + 395 = 450.8. That is a bit off the 562mm listed on the Savage 5t specs.
Going with your Baja 5t measurements of 21.25" or 540mm, something is a bit screwy with the description of the Savage 5t's extra length. To get an Xl up to 5t body size it would take 145mm extra, or 5.6".... All i can say is that front dogbone it lllloooonnnggg...
I will do more thinking and figure something out!
So the Xl tranny placement will be fine for me, I am wondering how much space will be left in front of the tranny? Since the XL uses the same front center shaft as the X, I should be able to see the difference with some quick measurements.
03.09.2009, 06:00 PM
Interesting pic Tim, thanks!
So I scratched my head a bit, and came up with the front driveshaft on the savage 5t must be somewhere near 220mm long. Got that from the 5.6" measurement that would be needed to get the XL chassis up to the 5t bodies wheelbase and added it to the 78mm XL front dogbone....
8.6" long front driveshaft is quite a length... Not sure what the flm tranny forward rear driveshaft length is, but i cannot see it being that long...
Leaves plenty of room for batteries up front, even after you figure maybe 2" for the servo mount.
However, looking at you pic of the xl with the lipos behind the tranny I think I would prefer to use the slightly shorter wheel driveshaft (hpi p/n 86134 123mm) as the rear center driveshaft. That would move the tranny back about 1" compared to the XL, and give a bit more flexibility in the tranny mount area. It will also add almost an 1" to the front driveshaft, which could really do with a carrier bearing or something like that, considering its length.
If I make a carrier bearing I could use a pair of the 84mm driveshafts (hpi p/n 86056) which are the stock X rear center shafts. The carrier bearing assy could be whtever length I want, with a dogbone cup on each end, and be supported with a pair of cutom crossbraces with bearings... I think this is preferable to the one piece front shaft, as it will have to be quite thick to handle the loading along its lenght. And I think the carrier bearing assy will be easier to make and I like the idea of off the shelf shafts, as they tend to be the weak/wear point anyways...
