03.19.2009, 08:59 PM
Where could I get wheel extenders to use w/truggy wheels
othello
HV basher
03.19.2009, 09:10 PM
Mugen MBX5T uses extended wheel hubs or look for King Headz Wheel Hubs +12.7mm.
03.19.2009, 09:15 PM
Thanks...I was thinking of using a mbx-5T as a base vehicle seeing as I have a mbx-5 and love it.
I will need toget the biggest shocks that will fit in it to help as well as some chassis braces to make it stiiff enough
othello
HV basher
03.19.2009, 09:28 PM
You could use half offset truggy tires to increase width even further. A friend of mine drives an MBX5T which is as wide with standard offset tires as my Mantis truggy fitted with half offset tires.
rotary rocket
No Pistons
rotary rocket's Avatar
03.19.2009, 11:01 PM
I'll build one once CC puts out their 8-12 cell controller.
The 1/5 scale that I made from emaxx parts I ended up using two 7XL and two ESC. I like the idea of a single motor.
