Go Back   RC-Monster Forums > Support Forums > Team Tekin
TekinTeamMgr
TekinTeamMgr's Avatar
03.22.2009, 09:29 PM
I doubt it. Make sure to cut the motor wires to equal lengths, it helps. A bad connection certainly could cause that issue.
  Send a message via Yahoo to TekinTeamMgr
whitrzac
Can't catch this...
whitrzac's Avatar
03.22.2009, 09:43 PM
but it only cogs trying to go backwards..
whitrzac
Can't catch this...
whitrzac's Avatar
03.23.2009, 09:16 AM
one little thing I noticed, you can't re calibrate the esc when using a external BEC....it just sits there trying to find neutral.
crazyjr
crazyjr's Avatar
04.29.2009, 07:14 PM
for programming, you need to reattach the red wire and use a 2s pack
whitrzac
Can't catch this...
whitrzac's Avatar
04.30.2009, 08:21 AM
lil late now...
the RSpro is being sold for an RX8
whitrzac
Can't catch this...
whitrzac's Avatar
05.02.2009, 07:52 PM
lil late now...
since everyone seems to have an "good" esc at the LHS, how would an RSpro fair with a tekin truggy 2250 motor in an e-maxx? with the usual bec/caps/fan...
TekinTeamMgr
05.02.2009, 11:00 PM
I'd get an RX8. The RS Pro is not intended for that application. I always recomend the right esc for the job.
However that being said I'm sure it'd be ok. Making sure that it's setup properly with low timing and in Dual mode. Proper caps,etc.
