speedemall
04.01.2009, 02:05 PM
Originally Posted by SidewaysLS4 View Post
I ran those, broke 3 of them at the hub, and one was shattering around the tire/rim edge. And this is on a 1:10 buggy converted to 17mm hex (lightweight). Very fragile IMO. They are supposedly coming out with a revised wheel for these issues, but I'm still waiting for my warranty replacement to see how those are. Also, have a wheel balancer, they tend to need balancing badly.
I have OFNA wheels and OFNA belted treaded tires now, you gotta build them yourself, but they dont break and require less lead to balance them.
were they the 5 spoke design?
brushlessboy16
brushlessboy16's Avatar
03.31.2009, 10:21 AM
Bad already. DO NO RUN THE 2650 ON 5S!
Its been discussed many time.
speedemall
03.31.2009, 10:32 AM
good thing you told me before my first run!! Thank you!!! Can you link me to a thread or give me the reason why? I am going to buy packs today and need to know what to get asap.
speedemall
04.01.2009, 10:54 AM
even though my car is running mod1 spur My LHS's only have mod 8 pinions and spurs in stock as this kind of setup is just not popular here.Would it be safe to convert my spur and pinion to Mod 8 being that it is an on road car?
FYI if that this the castle motor it is only rated to 4S - I personally ran mine for a few times on 5s before they updated the spec and it was ok.
Just be advised that you are running out of spec and hence warranty...
You are just missing one bit of info - desired top speed...
speedemall
03.31.2009, 10:35 AM
so the limit is 4s regardless if it is v3? I would like to get a top speed between 45-60 mph nothing to hairy.My slash is clocking 53 on a 9000kv 2s pack and I'm comfortable with that just not in the dirt
03.31.2009, 10:36 AM
Castle only rate the MOTOR to 4s : 2650*4*3.7 = 39.2K RPM... Guess they don't want them going higher....
I have run on 5s just be aware of warranty issue.
PS MMM v3 ESC is rated to 6s.
03.31.2009, 10:38 AM
Option 1:
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Additional Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Battery Voltage: 14.8
Motor KV: 2650
Tire Diameter (inches): 4
Top Speed (MPH): 49.0784 MPH
03.31.2009, 10:39 AM
Option 2 - No warranty
Additional Ratio: 1
Pinion Tooth Count: 13
Battery Voltage: 18.5
Motor KV: 2650
Top Speed (MPH): 49.8453 MPH
04.01.2009, 11:04 AM
Not really as no one makes that I am aware of a spur gear for and IGT that is Mod 0.8...
Mod 1 is not that uncommon any more - for now just buy the pinions from mike.
speedemall
04.01.2009, 11:45 AM
will do thanks!!!
SidewaysLS4
04.01.2009, 04:27 PM
BBS style.
