lutach
lutach's Avatar
03.31.2009, 04:47 PM
Originally Posted by johnrobholmes View Post
Yep Yep. I could hear the pinion slapping around too. Those 4 pole motors really carry a big stick when it comes to pole/slot attraction.
On the track they are unbeatable. I've beaten everything made so far for the 1/18 - 1/14 scale using the 6000Kv version. Even guys running the sensored Novak micro stuff had no chance. I can go balls out for 10 minutes and nothing heats up and that is a plus as I can gear up if I want to go faster for any 5 minute race. I just finished the mounting hole patterns I'll be using and it should fit any micro out there. The best part is that the motor uses normal 3.17mm (1/8") shaft and those in our micro/minis will be hard to bend or break.
