04.02.2009, 01:58 PM
Are you using mixing you need to probably invert that chanel
laser_cart
04.02.2009, 02:03 PM
I'm running a Y harness on channel 2 for the ESC and brake servo
04.02.2009, 02:04 PM
Sounds like you are using a y cable. Nothing you can do for that except put the linkage 180 deg from where it is now so that the lever action works in the correct direction. I had to do this with my revo.
laser_cart
04.02.2009, 02:14 PM
im using a y cable i will try that but when i hit the brakes the RED light comes on does this mean something is wrong
