boostedg60rado
04.08.2009, 06:31 PM
also who would take a 1/8 buggy and run 2.2 wheels that is about the stupidest thing i have ever heard you are better off running the 17mm 1/8 wheels stonger and higher top speeds.
04.08.2009, 06:46 PM
Originally Posted by boostedg60rado View Post
Well i already own a 1/8 buggy and that is not the topic here. I love my crt.5 for its small size and the fact it hauls butt.
Plus there is alot the crt.5 can do that the 1/8 buggy cant like be so nimble and handle the way the .5 does.
Just my view point man... I mentioned the 2.2 wheels for the crt.5, not the 1/8 buggy. I personally fell that the hyper8 handles better than the crt.5. Mine had a decent 3s setup (hacker c50 8l with a mm and 3s 5000 neu lipo) and was geared for about 45mph. I broke a few things on it that should not have, and I never really drove it hard after that. My hyper (actually had a few 7s and an 8) takes abuse much better and handles the variety of terrain I run on much better than the crt.5 ever did.
But that is just me... My suggestions for the .5 are the rcm chassis, alloy hubs and knuckles, jato front shocks, 1/8 buggy shocks for the rear, and some traxxas 2.2 dish wheels with gladiators. This seemed to be the best setup I found.
GO-RIDE.com
04.09.2009, 11:01 AM
Nothing in the RC car world is as strong as a 1/8 buggy. My Losi 8ight takes horendous abuse and just doesn’t break. However, I really like driving my CRT.5 on smaller tracks a lot more than the 8ight. The 8ight is just not as fun or challenging on a 1/10 track. With that in mind I’ve owned 2 completely different CRT.5s.
If you are going to run a lighter 2S system like a Mamba Max and 4600 or a Novak GTB and a 6.5 then keep your car light and use the stock buggy wheels. I’ve run both of those exact systems and they work very well in a stock wheel setup crt.5. Running something like this will require very few if any upgrades for strength. With this setup I run a stock car with spring, piston and oil changes only.
If you are going to run a heavier 3S system like a Mamba Max and Medusa 50x3300 then you might want to go all out in upgrades. My crt.5 setup like this uses 2.2 truck wheels, and RCM extended chassis, lots of aluminum parts upgrades (most important is the servo saver), and 1/8 scale shocks. For additional strength I boil the front and rear arms for 10 – 15 min and use a 4mm upper turnbuckle on the front.
E-8ight - Tekin RX8 2000kv/4S
