04.13.2009, 05:03 PM
Did some more measurements, and the rear center driveshaft from the Muggy will fit better than the xl driveshaft, so I ordered one of those. It is slightly shorter, and with that the truck wheelbase will be almost identical to the bodies wheelbase.
Just need to snipe a good deal on a set of flux tvps and I will be able to cut the new tvps.
Savage03
04.22.2009, 01:57 PM
Progress?
04.22.2009, 02:39 PM
Originally Posted by Savage03 View Post
Progress?
I have the muggy rear driveshaft, and am waiting on the flux tvps. Once they come in I can mock the rear of the truck up and figure out what I need to do to the front. Wheelbase will be right at 15", so I need to add a few inches to the front of the tvps I will be making. I like the 25 style tvps more than the X, but whichever front section works better with the flux rear is what i will use for mockup. Cutting the new tvps will not take long, I plan to make them symmetrical save for the area next to the motor which will be clearanced for a flux-style esc mount.
Still waiting on the motor back from neu...
Savage03
04.22.2009, 02:42 PM
So your still going for a longer wheelbase then the flm tvps give? Last i talked to you you talking about the 1/5 size but looks like you toned it down some.
04.22.2009, 02:45 PM
Yeah, the 15" wb fits the proline 650 body almost perfectly. I have the body, and the front muggy shaft was 7 bucks, so it is a cheap build. A sheet of the 6061 al was 20 bucks, and I have everything else laying around.
My buddy is still working on the 5th scale chassis for the savvy. He is doing one for the 5t body, and also another to fit the 5b desert rat conversion 5t body for me. Should be nice. I have the power system for that lined up save for a good HV esc. I think Lutach will be able to provide me with something...
Savage03
04.22.2009, 03:02 PM
Hopefully you get something worked out soon, wouldnt mind a better balanced setup at least but the 5t size is exciting.
04.22.2009, 03:20 PM
I should have it mocked up by this weekend, and hopefully get the tvps cut too.
Just received the TVPs (yay) and had a look at it mocked up. Looks like it will be pretty easy to cut them out. Battery mount may be a bit high up, but it is a monster truck... Balance side to side seems good with the motor offsetting the lipo. Wheelbase is very close to the 650 body, which I am happy about.
