04.20.2009, 01:36 PM
Originally Posted by Urgeoner View Post
Thanks linc!!
Now you say they must be series lipos, or I can take 2 parallel lipos but need to hook them up to the charger in series? This is whats confusing to me. I see 2s1p has 7.4v but has 6500 mah, while a 2s has 7.4 v and only 3250 mah...or is it reversed?.
Best to wire the lipos in series for 4s1p. I am guessing that you plan to run the 2 2s packs in series for 4s in the car, so you should charge the same way. That way you have all 4 cells balanced out. Sounds like you are running 3250mah packs, so your charger settings would be 4s 3250mah with a 3.2amp charge rate.
