Post Pictures of your Custom Switch!!! -
05.03.2009, 09:12 PM
I put a new toggle one on today, and put it on the cooling fin for the battery compartment (E-Revo.)
Ill post pics tomorrow
lets see yours and where you mounted them!!
6s MMM E-Revo l Rustler VXL l Stampede XL-5
Here's mine, i have used Deans Micro Plug 2NB.
It looks kinda big in that pic, but in reality its smaller than original...
Only thing is that i accidentaly soldered male plug upside down.
I don't have any pictures of just the switch, but I always use a toggle and cut a custom L bracket. Instead of a hole to mount the switch, it's a slot so removal is simply a matter of loosening the nut and sliding it out. If it's a SPDT type, I cut the unused contact and heatshrink the whole switch.
You can make out what I mean in this pic (on the upper plate, by the split loom):
Yep. But it does have X2 shocks. I wanted more ground clearance and suspension travel than the stock shocks allowed, and the 808 shock mod wasn't good enough.
The switch powers the ESC on/off. If off, it won't arm. This means less spark on hook-up since it doesn't have to charge the caps AND beep the motor. Also used for ESC/radio calibration and basic programming. Yeah, that's not a big deal, but it's easier to switch radios (if someone else is bashing with me and need to use my extra DX3.0) and do the binding process by powering up with the switch instead of trying to hold the bind button and connect the batteries. Not a big deal, but it's a reason.
