Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
littlegiant
05.11.2009, 06:44 PM
Any idea if the 3674 2350Kv ezrun motors are 2 or 4 poles?
What about the KD36 range of brushless motors? Are they 4 poles motors?
Oh and the KB45 brushless motors? Any idea if they are 2 or 4 poles motors?
superek4
superek4's Avatar
05.11.2009, 06:49 PM
No they r all two pole
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
littlegiant
05.11.2009, 09:14 PM
Hi, but somewhere on the net I've seen a pic of a 2350kv (ezrun motor) with some sort of carbon wrapping around the magnets. Did I see wrongly?
What about the 44mm diameter ezrun motor? is it a 2 pole as well?
superek4
superek4's Avatar
05.11.2009, 09:41 PM
Yes it's all 2 pole, 4 pole will b neu n medusa
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
05.11.2009, 09:54 PM
The KB 45 motors are also 2 pole!
I want a look inside the HW motors myself. My buddy wants a budget buffy system, so he may get the HW80 and one of the motors, probably the longer model, should handle the heat better?
superek4
superek4's Avatar
05.11.2009, 10:13 PM
Yes it shld handle better heat but also draw more amps
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
05.11.2009, 10:16 PM
Seems like the difference between a L can and XL can feigao... Similar KV and the longer can will draw a bit more, but run cooler and thus more efficiently. So the amp draw ends up about the same... But the longer motor can run longer and will put out a bit more power.
nusti
nusti's Avatar
05.12.2009, 03:34 AM
I run the 2350 kv model in my emaxx with a HW150A. The first one i blew up in 5 minutes of runtime, probably a mounting mistake. I may have used mounting screws that were too long and that bent the inner wire wich in their turn shorted with the magnet. Or just a production failure :)
Anyway I got a new motor from HW (GREAT service) en used shorter mounting screws. I had three runs up to now. One to test if everything works and two runs at full power. Constant high speedruns/full throttle in a park on long grass. I use a 21/62 gearing and 2X 2s2p 5100maH 25C lipo packs. The runtime was 13 minutes. the motor didn't get warmer then 51 degrees centigrade. This is with a heatsink and fan. The lipo got handwarm as did the ESC.
I think it's a great motor for bashing and it's a cheap setup. For racing I will use a medusa
