Can a BL motor be run in reverse-rotation without any loss in power or efficiency?
05.16.2009, 04:23 PM
just switch two of the three wires. everything is the same but the rotation.
Find all posts by _paralyzed_
2
florianz
05.16.2009, 05:20 PM
...if you would be using a system with sensor cables, you may not just change the cables, that can blow the esc. without sensor no problem.
florianz
Find all posts by florianz
3
littlegiant
05.16.2009, 05:31 PM
Wye motors run better in one direction.
Delta motors run the same for both directions.
But Wye motors have better torque and efficiency than delta motors and although it has different performance in different rotational directions, the difference isn't alot.
10:00 PM
littlegiant
Find all posts by littlegiant
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
