D8 Driver
05.25.2009, 01:08 AM
I'm using 10, 30, and 5K F-C-R on my ST RR running on 5S.
awesoming, that much in the center! wow, i have a kyosho electric st-r, with 5-7-2k and i am can do wheelies off the line pretty easy. how do you prevent wheelies with such a heavy oil?
i ran 2650kv mamba Creation combo, 16t pinion, 44 spur, 4s 4000mah, weight 9.4lbs
d-fly
05.25.2009, 09:31 AM
he is running a motor with alot more torque.
Aceldama
Aceldama's Avatar
05.27.2009, 02:11 PM
So after putting 100k in the center I gave it a quick test run on and offroad today.
It still only wheelies if you punch it from a nearly dead stop on tarmac. It's much more fun on loose traction surfaces now, and it gets moving a lot faster. I'll probably put thicker fluid in the rear diff as well because it seems to be completely open right now, I might try 7k in the rear.
