Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
Rebelgium
05.26.2009, 08:06 PM
Looks very pro MC. :)
Question,
do you compensate for the CF plate on top, and the one underneath you placed earlier, by using longer screws for the rear shock mount?
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.26.2009, 09:07 PM
Question,
absoloobly I use M3X.5X45 mm cap head screws 12.9, they stick out the bottom like I showed in post #32 and I lock them up with M3 nylok nuts from underneath the chassis.
No brain, no headaches.
Rebelgium
05.26.2009, 09:34 PM
Ahh right, I remember that. Man that thing is going to be bullet proof, what I like most is that it just looks so professional.
I copied your idea of the rear skid plate made out of cheap sheet metal a while ago, works great.
Today I was looking to make one for the front to, as it is needed most there.
It ended up nice, and without any drilling into original parts. (I wanted to keep stock parts undamaged so it'd be easier to sell later. I have an E revo, and want to go BL later... money you know)
Deans deans deans deans
mistercrash
Guelph, Canada, eh!
Deans deans deans deans - 05.28.2009, 01:50 PM
I'm dizzy from the soldering fumes
A little thing I do when I solder Deans plugs. Although I am very careful and plan ahead, on occasion, I have to keep the soldering iron tip longer than I should on the Deans' metal tab making the plastic start to melt and the tab moves and becomes crooked. This results in a bad connection or no connection at all. You know, you suddenly have a little twitch and the iron tip moves with the wire and you try to reposition it, it only takes a couple seconds but that is enough to over heat the plug's metal tab.
Some say to connect a male plug into the female plug you want to solder wires to and vice versa. That extra plug absorbs a lot of the heat and often makes for a poor soldering job, cold solder.
So here's my trick, I stuff tiny pieces of hard wood in the female plug I want to work on. Those pieces of wood have been sanded down carefully so that they fit snug but not tight. The wood does not absorb heat and it holds the plug's metal tab in place in case something happens and the plastic starts to melt. For a male plug, I took a scrap female plug and yanked the metal tabs out oh it and replaced them with the wood pieces. This holds the metal tabs of a male plug in place in case the plastic starts to melt. Easy and effective, it made the job much easier.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.28.2009, 09:31 PM
...I have to keep the soldering iron tip longer than I should on the Deans' metal tab making the plastic start to melt and the tab moves and becomes crooked. This results in a bad connection or no connection at all.
You should try a more powerful iron, or a soldering gun. I use my 230W gun to solder Deans and 5.5mm bullets. I let it heat up for a bit so when I put it on the Deans' solder tab it heats/solders so fast that the other end barely gets hot. It also helps to tin the wire/tab just before soldering it so they're still warm and the solder re-melts more easily.
mistercrash
Guelph, Canada, eh!
05.28.2009, 11:23 PM
I use this and I also have this for big jobs.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
