Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.28.2009, 09:31 PM
Originally Posted by mistercrash View Post
...I have to keep the soldering iron tip longer than I should on the Deans' metal tab making the plastic start to melt and the tab moves and becomes crooked. This results in a bad connection or no connection at all.
You should try a more powerful iron, or a soldering gun. I use my 230W gun to solder Deans and 5.5mm bullets. I let it heat up for a bit so when I put it on the Deans' solder tab it heats/solders so fast that the other end barely gets hot. It also helps to tin the wire/tab just before soldering it so they're still warm and the solder re-melts more easily.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.28.2009, 11:23 PM
I use this and I also have this for big jobs.
No brain, no headaches.
Currently Active Users Viewing This Thread: 9 (0 members and 9 guests)
