aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.01.2009, 12:23 AM
I will be running 2 of the turnigy force hv escs in the baja 5b conversion... Hope they do well. I plan to use mech brakes, and not have reverse... I like reverse though. If someone brings out some potent 12s car escs I will swap to them for reverse. Although mech brakes on heavy vehicles is a good idea. I can mix mech and elc brakes with the m11 so that is cool too. I may even be able to switch off the mech brakes and use reverse, will have to see if I can assign that feature to the radio...
I still haven't bought any of those K-Force ESCs yet.. but I'm sure they're better than the older model... what motor you plan on using for the 5B, and batteries?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
06.01.2009, 10:22 AM
I plan to use 2 1521 2y motors, and most likely 10s. I have enough fp 5000 25c cells to do 10s (I actually have enough to do 15s all matched). 10s with the gearing I have will do 50mph according to the calc, so that should be plenty for me. Need to spend some more time on the baja, other projects seem to be overtaking it.
06.03.2009, 04:24 PM
...Need to spend some more time on the baja, other projects seem to be overtaking it.
You need to make time by giving away some of your other projects to worthy members here.
06.03.2009, 11:28 PM
I would if anyone here was good enough to finish them up properly, and I am sure Mike is way too busy...
