06.01.2009, 04:29 PM
On the other issue, sounds like the magnet has detached from the shaft- if it isnt broken or cracked, you should be able to glue it back in place with something like jbweld or red locktite.
scarletboa
scarletboa's Avatar
06.01.2009, 04:47 PM
thank you. the motor still spins smoothly and doesn't heat up really bad, so i'm hoping it is just detached and not broken or cracked.
