nitrostarter
nitrostarter's Avatar
06.08.2009, 12:30 PM
Correct, it should be able to do upto 5c charge rates.
I think Hyperion released the 720i charger in connection with their newest line of lipos that are coming out. They have a 5c charge rate, a newer material which isn't supposed to be affected by the rapid charging. And they are fairly cheap as well, IIRC like $110 for a 5000mah 3s with the 5c charge rate.
http://aircraft-world.com/shopexd.asp?id=6229 These actually look decent as well!
I have the 720i also, and love it. Just make sure your Power Supply is up to par. I've maxxed out my 12amp cpu supplies trying to charge some larger 4s and 5s packs at a 1c rate. I have a 30amp rivergate now, no problems yet...
N. Rustler conversion
06.08.2009, 01:01 PM
Those lipos look tasty, and the price is pretty good too. Not sure how fast the 610I will charge, think it is 2c max.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2009, 01:34 PM
Nitrostarter, I love you. I was going to get me a couple of those Turnigy 5000mah/3s/25c packs for $42 a piece... screw that noise I'm getting these Hyperion packs.
What cells do they use? They don't use Enerland anymore do they?
06.08.2009, 01:42 PM
If you look around on that site they have some killer closeout deals on the enerland cell packs. I found one in particular that looked promising, a 6s pack for 90 bucks...
