06.10.2009, 11:57 AM
Metalman had a link to a twist grip control that would run a rc type esc. Can't remember where he had it though.
brushlessboy16
brushlessboy16's Avatar
06.10.2009, 12:21 PM
"Bad lutach first"
You know what's coming for you Ben .
No Ben, don't do it. Steel is much harder then aluminum and if it bends, it'll be much harder to bend it back to it's original place . So have you fixed you mount yet .
"Good lutach second"
There are some very intelligent guys in the forum who has vast experience with such a project. I'm sure they'll be here guiding you.
Thanks luciano, but i have no problems with steel, it will be built with braces etc to stop from bending..
You can use a servo tester for controlling the speed controller if you have an rc type controller.
I know I can, but twist grip would be pretty neat
I was in Academy Sports this past Saturday and stumbled upon the battery powered bicycles for him and her. They use a brushed motor like the electrics scooters do. They just basically adapted the scooter setup onto a bicycle.
Yea, but the speed controllers they use are not as efficient or powerful as any Rc controllers. Im probably gonna use my MMM for the moment in this one.
A searchin' I will go.
THanks for the info guys.
Now, since i want to retain the stock pedal system- would i be able to set a slight drag brake on the MMM and use the regenerative abilities of the speed control to recharge the batteries? I dont know how much power the regen braking actually saves..
