solder -
06.23.2009, 09:26 PM
so i did a search for solder and came up with 20 pages. so what solder % and type is everyone using for motor and batteries
that is all
thank you
06.23.2009, 11:18 PM
I use 60/40 Rosin Core from RadioShack.
06.24.2009, 12:55 AM
Yep, that's what I use too...
RC-Monster RC8T
06.24.2009, 01:00 AM
me 3, but not from radio shack
06.24.2009, 01:43 AM
Ditto on the 60/40. I got mine form the hardware store. Make sure you get electrical solder, not plumbing. I also picked up some silver bearing solder, but I have not tried it yet. Supposedly it melts at higher temperatures and cools of nice and shiny. Neither seem to be necessary fro what I am doing...
06.24.2009, 01:47 AM
lol, yeah. Plumbing solder is usually acid core. Not good at all for electronics work!
06.24.2009, 07:00 PM
so any 60/40 is good with rosin core. what is the main difference between 60/40 and 70/30 i know its tin to lead ratio so more tin is stronger, but melts at a higher temp?.
so basically 60/40 is 60/40 no matter what brand, or are their quality differences.
Soldermaster Extraordinaire
06.24.2009, 07:23 PM
The 60/40 is fine for 90% of general electronics jobs (r/c included). I have some of the silver bearing solder as well. It does have a higher melting point and so you might need a higher wattage soldering iron/gun. The advantage to the SBS is that it has less resistance than the standard 60/40 and it makes a much stronger joint when it cools- both due to the silver content.
06.24.2009, 09:12 PM
so sbs is harder to use but better results?
06.24.2009, 09:20 PM
Yes. It's also more expensive. Again, due to the silver.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
