drkdgglr
07.17.2009, 12:55 AM
If you are peaking at 100-125 amps, the voltage of a pack rated for 100amps will drop = less speed.
If you get a 30c or higher rated 3s5000mah pack, you'll get 150a continuous and the batt will hold it's voltage better. Take a look at the hyperion35c thread on this forum. At 20c these packs hold 3.7v per cell.
Use the speedcalc and see how voltage drop affects your speed.
