zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 01:32 PM
My 7XL will draw 6.5 amps no load on 6s lipo... so it could be right. Maybe check Fiegao website for idle currents?
littlegiant
07.19.2009, 12:00 AM
Hi, thanks alot for the info. I've tried searching on feigao website but all I have found is the max current spec of the 540 motors.
zeropointbug
Z-Pinch racer
07.19.2009, 12:19 AM
No prod bob.
It's probably right... Fiegaos aren't exactly made with high quality control, so everyone's results may vary a bit.
littlegiant
07.19.2009, 12:28 AM
No prod bob.
I've tested the rest of my motors and found that motors with stator has a lower idle current. Motors without stator cores but have very strong magnets have higher idle current. Higher KV = higher idle current.
Well it all makes sense now. :D
All tested are 2 poles motors.
J57ltr
07.19.2009, 12:34 PM
I don't understand your last post, a stator is the stationary portion of the magnetic field. Basically its the windings in the motor. So as I like to tell people who walk up to me and start speaking spanish: "No Nintendo."
Jeff
littlegiant
07.19.2009, 12:47 PM
Jeff
My mistake. I left out one word. Stator coil and stator core. Some brushless motors do not have stator cores (aka air cores) to concentrate the magnetic field. u aren't totally right either. :D Good day.
J57ltr
07.19.2009, 01:05 PM
I was just trying to be funny. How am I not right? The stator is the stationary part of a brushless motor. It's also the stationary coils of an alternator or generator, or any motor type that uses a winding that is stationary position usually on the outside of the rotor or armature as the case may be. In an outrunner it's still the stationary portion of the motor.
I guess if you go by a wikipedia definition or something then I could be wrong. I guess you are referring to slotted vs slotless? (idk I’m asking)
Jeff
