E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.19.2009, 04:16 AM
Originally Posted by NoControl View Post
Yea the idea of having all the spurs and a few pinion gears on hand is nice, I keep 20-24t pinnion and 54-58t spurs, the 68t spure can only be matched with an 18t pinnion or lower using the standard motor mount plate.
BTW I also don't like Castles stock monster 18t pinnion can never stay on the drive shaft, it could just be me though.
Not true! I know at the very least a 68/20 works as thats what I ran for a long time! Also 68/23 works
sikeston34m
sikeston34m's Avatar
07.19.2009, 06:29 AM
Vibration Loosening.
A Little Blue Loctite on the grub screw and even a little on the motor shaft helps keep things tight and running right.
Be Sure to get the Blue, You don't want the Red Loctite.
Red Loctite requires alot of heat to be removed. The Red holds so strong, you will strip the grub screw before it will loosen.
The Blue is made to be removeable. A good choice.
NoControl
NoControl's Avatar
07.19.2009, 11:36 PM
Yea I did use blue locktite, both on the screw and to fill the empty space between the shaft and the gear, and it still would slide forward, I think they just used a screw that was too small, I've since gotten some RR 20,22,and 24 tooth gears and they have a slightly larger screw and I have yet to have one of them slide forwards.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
