fastbaja5b
fastbaja5b's Avatar
07.21.2009, 09:04 PM
I was banned by hopmeup on ebay because I left them neutral feedback based on the quality of the product they were selling. Dont base your opinion of A123's on what you got from them - they really are good reliable power. Not as much power as lipo, but likely much more reliable.
To do a 2S/3S set up (as 5S), you just need to remove the Flux battery wires, and insert a single pack connector - this will make the flux think it is seeing one pack. Oh, and you'll need a series wiring connector for the packs (or is that parallel???) Check Brians speed calculator page on battery wiring to verify the layout.
Ok thanks, do you find the higher internal resistance of A123 vs Lipo presents an issue?
Say Less, Do More.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.21.2009, 09:52 PM
Absolutely not. What type of issue are you referring to?
JThiessen
JThiessen's Avatar
07.21.2009, 11:35 PM
I didn't notice it. I ran them hard, charged them fast, and for the most part, they came back ready for more. I ran into some balancing "challenges" with one battery, but with some TLC, it came back every time.
zeropointbug
Z-Pinch racer
07.21.2009, 11:53 PM
I never once balanced my packs, lol... I just don't think they need it with RC packs. I charged them at the max I could which was 10amps and is the rated fast charge for them as well.
The low internal resistance may affect the durability of the esc for absorbing back EMF when braking, but I have had no issues.
I am not calling Freeze a beginner, but I think all beginners should use A123 cells, they provide them with plenty of power, durable, and you can't really get into a dangerous situation like could happen with lipo if a VICTIM does something stupid with the pack, that he may or may not have known you could do, or not do.
But IMO, you should get the Hyperion G3 packs, I am continually amazed at what these things do to my truck. And SPEAKING of durability, I just ran a half run with my Revo geared for 65mph running in the ditch/road... I was scared, I am not joking here, every little bit of throttle increase would lift the front of the truck sky high. I didn't even know my little 1512 could pull the truck so hard with such tall gearing! Brought the truck in, I put ~2400mah back into the pack @ 20amps(immediately after the run mind you) and they were stone cold as well!
I am not speaking out of my @$$ here (although like Pimp said earlier would be cool if you could), my Revo can handle that tall gearing only because my Quark esc has been modified quite a bit to handle anything I can throw at it, which as you can see, is alot.
