Go Back   RC-Monster Forums > Support Forums > Novak
07.23.2009, 06:44 AM
Or if you buy from Mike RCM or Holmes hobbies they will set the voltage on a BEC for you before shipping.
You also have to leave the ESC in the off position when using an external BEC to avoid dual powering the ESC.
JThiessen
JThiessen's Avatar
07.23.2009, 11:10 AM
AND one you turn on the pack switch, you need to turn the ESC switch on then back off (info that is NOT included in the instructions).
Ta Man: Have you ever used that Novak BEC before? In the link it says it allows up to 7S usage, but I'm fairly certain that does not mean that if you added this, you cant then run 5,6,7S on the HV system, correct?
ozpall
07.23.2009, 11:31 AM
so i turn the hump pack on, then the esc ON and OFF? and leave it off? whoa i didn't know that, i was running with both on.
great info in this thread for newbies
ozpall
07.23.2009, 11:34 AM
JThiessen, i think i've seen you on diesel resource. i got an 03 drw with a couple of stuff done to it as well.
ta_man
07.23.2009, 12:34 PM
I have one of those BECs on my Havoc 3S (the internal BEC won't run a high torque servo on 3S).
Right: You can't run more than 4S on the HV system just by adding a BEC that can take more than 4S.
Well, you could try, but Novaks aren't like Castles (the MM for instance that lots of people use on 4S and some even on 5S).
JThiessen
JThiessen's Avatar
07.23.2009, 03:11 PM
Also not the novak is only good for 3 amps - a strong servo such as the 7955 tg is rated over 4 amps at stall on 6v
Yes, good point.
I just found that out this last Sunday by searching this forum while trying to get my brother in laws maxx running.
Yep, that would be me. I dont get on there a whole lot anymore - got my 06 set up about where I want it now. Is yours an HO or an SO? If you've got the HO, and you dont have any of the electrical gremlins, keep that thing as long as you can.
ozpall
07.23.2009, 04:08 PM
yeap HO 6 speed manual, no electrical issues but tons of drivetrain issues, been fighting the dw forever now.
JThiessen
JThiessen's Avatar
07.23.2009, 05:14 PM
OOOOHHH...as I recall, the success rate on solving that wasn't all that high. I also dont recall all that many bubble butts that had it. Good luck!
