florianz
07.24.2009, 03:59 AM
maybe there's a bad soldering, that can cause heat as well.
07.24.2009, 01:14 PM
Feigaos are not high quality motors. That's why it did not last long. Get a medusa, and since it's a buggy, a 36-60-2000 or 36-60-2200 will work great. If you're looking for more punch, check out the 36-70-2300.
13btoyrota
07.29.2009, 09:39 AM
While talking to somone at my local hobby shop i noticed a large 36x60mm motor behind them and it turned out to be a larg ducted fan motor from a plain. It is a himark 36-34-1850kv motor it looked like a good quality motor
and had all the corect size bolt holes, shaft size and is fined heat sink can.
It is rated at 1850kvand dose upto 22v and is rated around 1200wats and in the ductec fan setup will do 2000grams or 2 kg of thrust so i purchased the motor and put it in my buggy and its PURRFECT. With the 13t pinion and 46t spure it has just the right speed and the motor didnt even go above 65c and the esc and lipo's just got warm and i didnt even see the fan run on the MMM.
I stoped running it after 15min and seem it would still go for longer as i normaly only get 10min so the run time is also allot better.
This motor was also only $99 aus dollars and so far seems to be a good one and first run is better than the feigao motor ever was.
