zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.26.2009, 01:33 PM
Your choice - but I know what I'm gonna do - make scrambled eggs out of it!!!!
LOL nice
I only have 2wd right now because I just blew the rear diff (then swapped) after I got my G3's lipo packs. I plan to get the RCM hybrid diffs for it.
The diff had two screws worn away on the inside, and one of them was completely sheared off... I don't really know how that can happen in the first place? But the whole thing was held on by 3 of the 4 screws, but they were stripped, so the ring and pinion was popping, and the fragments from the screws just stayed inside with the spider gears and got ground up, spiders are fine however. IMO, it's the diff case screws which are the weak point; Traxxas really needs to address this problem too, they are being so cheap about it. I mean really, how much does 3mm screws cost?
JThiessen
JThiessen's Avatar
07.26.2009, 08:34 PM
Most of the time its the plastic case flexing that causes the issues - which is why a lot of us are doing ok with aluminum inner and outer cases on the diffs using the stock gears.
Jason
07.29.2009, 11:21 AM
damn I have only about 7 or 8 pack on my e-revo and the holes on each driveshaft are already enlarged and the ears start to twist only on 4s power ...
neu 1515 2.5d 1700kv
4s lipo 15c 6400mah
56t/21t gearing
the slipper was not so tight
anyone have found a fix maybe other shaft from other rc's ?
