nitrostarter
nitrostarter's Avatar
07.31.2009, 10:18 AM
Well I'm planning over 150mph, do I get a special hat too?
Glad to see you here Nic, and good luck at the event. Lets see some outrageous numbers again!
N. Rustler conversion
hoober
08.01.2009, 11:10 AM
If you make 150 , you get 1.5 hats.
Electric stock (2wd and 4wd) rule is pretty clear (I think) with a single 2S pack , but for electric mod can the pack be made with 4S of 2P cells?
The voltage max seems clear that it is intended to guard against overcharge, but there is a rule that is stating max of "4 cells" , my proposed set-up is technically 8 cells.
