08.01.2009, 11:44 AM
Originally Posted by T-Bro View Post
Probably the mgm that can handle 30cells/10s. Don't know much about this one you named. Is it good? Also how much, and how many amps is it?
Lutach, a long standing member here had some esc's made, a 6s 200 amp and a 10s 150 amp (I believe) Someone will provide a link, that is the LT10S he is talking about
Even a 100amp 10s is good for 3700 watts (37v x 100 amp = 3700 watts) which equals 4.9 horsepower. I doubt you will pull anywhere close to that kind of load with your setup.
Remember, as volts go up amps go down (with same gearing, higher gearing may be possible with increased voltage, but is unecessary due to higher motor rpm)
Tags
1527, neu motor
