emaxx 101
08.09.2009, 07:55 PM
Yeah I have, in the front and back.
Andrew32
08.09.2009, 08:08 PM
change your gearing.
whats the temp of each of your components
ESC
Motor
Batt
emaxx 101
08.09.2009, 08:22 PM
Esc stayed around 140-150, motor was 165f max., batts were 110f.
The Dan
The Dan's Avatar
08.09.2009, 09:02 PM
Those temps are actually quite good. Considering you're running 6S, if it was my truck, I would be amazed to see the CC/Neu motor reach 165dF after 15 minutes of running.
If you do still want to lower the temps, drop your pinion gear down to a 16T.
