kazuaki
08.15.2009, 03:36 PM
Originally Posted by jayjay283 View Post
will 2x 2s 1800 mah fully power it ? test runs showed you gained 10mph using an 8000 mah over a 5000 mah in a rustler by some manufactuers in speed tests. I run more in my transmitter (2400 mah 2s) my micro T that weighs 3oz runs on a 1800 mah. Just my thoughts, im usually way off
I can't fit a 4s battery in here. I bought the best batteries I knew of in the G3's. They are rated at 35C/65C, that's 63A continuous and 117A burst.
jayjay283
jayjay283's Avatar
08.15.2009, 07:55 PM
yeah I hear ya that seems more than enough then. I think that extra mah more applied to when lipos were 15c piles. Just threw it out there. 65 is pretty fast on 4s I agree with the homies, build a super aerodynamic nosecone lol
kazuaki
08.16.2009, 01:33 AM
The body is still stock. I think I am going to try sticking a wing on the front next, or some type of splitter. I figure that will increase downforce and eliminate some of the flow under the truck. Just need to find an appropriate wing I can use now...
