Thread Tools Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
GS-Racing XUT conversion
woom1970
woom1970's Avatar
GS-Racing XUT conversion - 08.15.2009, 03:37 PM
Here is my first BL conversion.
A GS XUT pro truggy,first XUT I have seen BL converted.
My first attempt was to use Hobby Wing 150a esc and the 2000kv motor with 6s lipo.
The HW ESC lasted 10 min before it blew up, then I bought an Mamba monster ESC ,then the HW motor blew up.So now I use complete Mamba monster combo and it works well.
Name:	Picture 025 (Small).jpg
ID:	7567   Click image for larger version
Name:	Picture 024 (Small).jpg
ID:	7566   Click image for larger version
Name:	Picture 029 (Small).jpg
Name:	Picture 032 (Small).jpg
TRX E-Revo BL,TRX Slash BL,Kyosho Lazer ZX-5 BL and GS-Racing XUT(Rue Edition) BL
Troopermanaic
08.26.2009, 09:42 AM
Hey I am dyeing to know how you did this. Can you explain in detail? I want to convert my XUT to brushless so badly. What would you recommend that wont burn out?
woom1970
woom1970's Avatar
08.26.2009, 03:31 PM
Sorry for my bad english writing.
My second setup for the XUT, I made a motor post from 4mm alu L-profile,used the orginale engine post holes in the chassis plate.Novak battery trays and Losi 8ight t mudgards .For the ESC I used a 3mm alu plate on the top off the middle diff post almost like RC-monsters post,so the ESC sits behind the diffpost above the driveshaft for the rear diff.I used a Traxxas Slash reciver tray and mounted it on top of the steering servo.
My brushless combo is Mamba monster 2200Kv,2x 4000mah 3s 30c lipo (cheap China battery)
So I can see no problem with 6s lipo on the Mamba monster at all.
MY spur gear is 58t mod1 and the pinion gear is 15t,but I will change to 13t
I run with open diffs to protect the drive train.
My XUT is built for bashing not for the race track.
So good luck with your conversion,keep me updated.
superek4
superek4's Avatar
08.26.2009, 09:48 AM
Of course it will blow up, 2000kv with 6s? Is 80km/h it's insane plus china motor can't take more than 70 over degrees.
Usually 2000kv we use 4s
I race 6s with 1600 medusa abt 50km/h no problem.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
superek4
superek4's Avatar
08.27.2009, 04:36 AM
what do u meant by open diff?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
woom1970
woom1970's Avatar
08.27.2009, 05:07 AM
not a locked diff,not using diff oil only a little grease on the diff gears
superek4
superek4's Avatar
08.27.2009, 05:59 AM
Bro, little grease or oil fill diff is still a diff won't save your drive train as jump or brake your drive train will still get jam up.
There's no slip action.
Ep 1/8 is direct drive unless u use a slip diff my Rc monster or tekno clutch system. Then it will save your drive train.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
woom1970
woom1970's Avatar
08.27.2009, 09:46 AM
I see your point, but in my head (maybe its wrong) Im thinking that thicker diff olil will provide more stress to the drive train.Try to drive a car with locked diffs.Take a 2dw car under ekstreme acceleration only one wheel will "burne"slip ,if the diff has a thin or no diff oil.Off course you loose traction, and there will be less stress on the drive train?? I think the same goes for a 4wd car.So my conclusion less traction less stress.
But again I not racing just bashing.And my conclusion might be wrong.
superek4
superek4's Avatar
08.27.2009, 10:33 AM
no Matter how thick the oil unless it's lock diff then there's no differenial. That's what a diff is for.
Only 1/10 on road we use spool or lock diff.
In 1/8 if your oil is thin the wheel spin faster making it harder to drive. No matter bash or race we use diff oil rather than grease becoz grease when get hot is not consistant.
We usually use thin oil at the rear diff.
Btw 2wd 1/10 ep cars has slip diff. Same goes for higher range 4wd 1/10 cars they have slip clutch.
Ask anyone here who does 1/8 conversion. There's no such thing as using thin/grease oil to allow less strain to the drive train.
When the gear is jam it's jam. Take alook at slip clutch or slip diff they have springs n metal plates to allow slip.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
woom1970
woom1970's Avatar
08.27.2009, 12:50 PM
Ok what oil wt will you advise for a allround truggy setup?
superek4
superek4's Avatar
08.27.2009, 01:29 PM
Front 7k center 20k n rear 3/2k
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Troopermanaic
09.01.2009, 02:59 PM
Can I ask you a question woom? How did you make that electric motor plate? do you still have the plans for it? can you be so kind to send me the blue prints so I can make one myself? I was gonna use a savage tranny to eliminate the roll before it catches gear but I decided I don't really care.
brushlessboy16
brushlessboy16's Avatar
09.01.2009, 03:25 PM
ITs an rc monster motor mount
using a transmission throws all your ratios off.
keep the CD
KISS.
Troopermanaic
09.01.2009, 03:51 PM
is it this?
http://www.rc-monster.com/proddetail.php?prod=RCMCRT1
brushlessboy16
09.01.2009, 04:16 PM
read it. its for an ofna. this is not.
there is a slight possibility that it fits though
