08.16.2009, 06:15 PM
A guy over at the traxxas forum bought one....
He said basically, its sturdy as such, but the quality of fit & finish was not too good.
Tranny wouldnt mount flat/flush with the chassis rails without some grinding, and as you can see from its pictures, Dan doesnt know how to use a tap set, so instead its held together with nuts and bolts, not terribly high quality looking. Works fine though, but I would rather spend the money on an FLM chassis, and then modify it like so:
http://picasaweb.google.com/buikpijn...bonLowerplate#
(you can use an aluminum plate ofcourse to save money vs carbon fibre).
Very simple to do and wil give exactly the same look ad effect, only, better....
Dan (Kershaw) is a good bloke though for what it matters.
