For you mbx-5T owners....what diff fluid are you using -
08.24.2009, 04:27 PM
I am targeting the Mugen owners specifically as I recently bought a Mugen truggy.
I am thinking of: 7F 15-30C 5R
I did do a truggy diff search and came up w/ alot of different set ups....so, this is why I am targeting Mugen owners
Good bad?
08.24.2009, 04:31 PM
20-20-5
slipperential in center
for very aggressive driving style
used to run 7-17-3 - not bad either
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
08.24.2009, 04:34 PM
I am only basing w/no sliperential...so your second set up would be good?
08.24.2009, 05:20 PM
for bashing go with thicker diffs so 20-20-5 will work well
Radek
*EX-10 Eurus*
08.24.2009, 06:23 PM
Excellent...thanks!
08.24.2009, 06:47 PM
just dont forget that oil won't last forever so you need to check it/replace it every few hours of runtime :)
Radek
*EX-10 Eurus*
08.24.2009, 06:59 PM
Funny you should mention that....on my mbx-5 buggy, my diff fluid seems to last forever. In my friends koysho, he needs to do twice the maintenance I do....go figure
HOOH HUAH HOOH! Aww Baby!
08.27.2009, 07:02 PM
I'm gonna run 5K in the center for racing. Not sure on the front and rear yet.
08.27.2009, 08:03 PM
5 in the center seems a tad light to me even for racing, but, seeing as I an new to truggies, I could be wrong
08.27.2009, 08:12 PM
I saw another guy running 5K in the center. I thought the same thing...but I guess I won't know til I try
I might go 10K just because I don't have a clutch and it's direct drive. Hmmm...
08.27.2009, 08:21 PM
I know that buggies/truggies are different, but before running BL in my mbx-5, I was running 7k in the center....after the conversion, I went up to 15 and it was perfect. I was thinking along the same lines for the truggies.
08.27.2009, 08:31 PM
Then I'm slapping in 10K for now. I think that's the highest I got at the moment. Need to stock up on MOAR.
is lovin life brushless
11.09.2009, 04:29 AM
what are the pros and cons of
a-heavier oil in the center
b-lighter oil in the rear
c-heavier oil in the front?
i am ballooning my front tires pretty badly and find my 5t doesnt turn in very well.
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
11.09.2009, 04:54 AM
DIFF OIL
THICKNESS CHARACTERISTICS
Front
Thinner
Increases steering into corners (off-power)
If oil is too thin the steering may become inconsistent,
especially it can lose forward traction (and steering)
during acceleration out of corners
Thicker
Increases stability into corners during braking
Increases steering on-power at corner exit
Center
Thinner
Front wheels unload more during acceleration
Decreases on-power steering (reduces oversteer)
Easier to drive on rough tracks
If a high-power engine is used you could waste too
much power and sometime cook the oil in the center
differential because it overloads
More off-power steering
Thicker
More all-wheel drive effect
Better acceleration
Increases on-power steering (reduces understeer)
Better suited on high-bite, smooth tracks
Car can be more nervous to drive especially if a high
power engine is used - you might need to be smooth on
the throttle
Rear
Thinner
Increases cornering traction
Thicker
Decreases rear traction while cornering
Reduces wheelspin
Radek
*EX-10 Eurus*
11.09.2009, 09:58 AM
That is a great explination and should be posted as a sticky somewhere!
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
