08.24.2009, 09:27 PM
I'll field that one= yes.
Much as I love the zippis for being cheap, part of me is cautious as they are still budget packs. What I do currently is use a pair of 5s 25c 4000mah lipos in parallel, that cost me $200 total, but it does give me extended run times, 8000mah on tap, and cooler running temps.
In your situation, I think its well worth spending just a little bit more money and getting a pair of 3000-4000mah packs in the 25-30c range vs one big 5s 5000mah lipo. If it means having ot save up a little longer, then thats what I would do to get a more reliable battery setup...
loa
08.24.2009, 09:42 PM
It was mentioned/asked several times weither or not you were running 1 or 2 packs at a time. Now we know, you plan on running a only 1 pack format.
Nope: I don't care if I use 1 or 2, I just want what's best for my set-up in general bashing conditions.
Then your battery decision will boil down to what kind of weight you want to deal with to keep your truck reasonably balanced, IE L to R and F to B.
Well that kind of decision is not really important for me. All I want is to have fun with my truck.
What types of packs do you recommend? And do you think that changing the motor is the more important thing?
Thanks guys!
Loa
