B4maz
09.01.2009, 02:51 PM
It seems pretty reasonable. Here is my TC4 on 12s Neu 1515/3D (click for bigger pic)
From Fast RC
From Fast RC
09.01.2009, 04:55 PM
Originally Posted by wallot View Post
will try to recalibrate the sensor. hope my cheap multimeter will be enough
punch wise they feel the same
//just checked the eagletree software and rezeroing the logger is done with battery connected and no load. How do I calibrate it after rezeroing?
Once you zero it out, you then run it in Live mode on a known load. I used a resistor pack to draw ~10A. Write down the current displayed on the ET software screen, and also what the current actually calculates/measures. Stop the Live mode running. In one of the menus, there is an option to calibrate the current and voltage by entering what the ET shows vs what you measured.
Originally Posted by B4maz View Post
It seems pretty reasonable. Here is my TC4 on 12s Neu 1515/3D...
A TC4 on 12s will be a whole different animal than a truggy on 5s. I think his displayed current is around half of what it actually is, which would make his mAh figure off as well.
