Kcaz25
Kcaz25's Avatar
09.01.2009, 03:52 PM
Lets see the thing!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.01.2009, 04:27 PM
Yikes, this is kinda old thread, it's like he just up and left?
Very nice looking build anyways!
Delta Maxx
04.04.2010, 10:22 AM
Hello again,
no sorry, i'm still alive!
but i went back to school so there is not enough time for all the projects.
here's a small update:
the centerdiffmount for my X2CRT centerdiff is already finished and mounted
but because of that i killed the transmission the drive shafts are to short so i make some.
front shaft/ left threaded
those are right threaded
rear shaft/ right threaded
both
overview
next step is make two pressureplates for the rear brakedisc because it has a special outline
first test will be posted
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
04.04.2010, 10:37 AM
Nice!... we need videos... won't the torque unscrew the shafts .... just curious... never saw them done like that before... very cool though
Alien
Delta Maxx
04.04.2010, 11:06 AM
Alien
because of that i have to make left threaded for the shaft in the front and i hope the brakingtorque is not high enogh to lose the loctite.
ANGRY-ALIEN
04.04.2010, 11:27 AM
Yeah... that's what I was thinking... they would experience quite a bit of torque from braking, accelerating and reversing... What if you used retaining pins that passed
through the torque tubes and threads after tightening them down, would it weaken the shaft? or would that pin be sheared off?
Delta Maxx
04.04.2010, 12:39 PM
yes, it would weaken the shaft, the pin wouldn't be sheared off, but it's
definitely no solution, the outer shaft diameter is 6mm with M5 thread there is
not enough material.
if the braktorque is to high i make a small spot weld (tungsten inert gas welding)
