scarletboa
scarletboa's Avatar
09.18.2009, 07:30 PM
i think the 1200kv would be better for 6s. that's less than 30k rpm. my 8xl (1600kv) ran 140-150F whenever i ran it with 85F ambient. that was with a stretched traxxas heatsink and the kershaw motor mount. that was on 6s with a $27 plane speed control. the hottest i temped it at was 160F after a 10 min. run with the gear mesh WAY too tight due to the motor mount shifting. it ran around 145F most of the time during my street bashing.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.18.2009, 10:36 PM
Awesome.. glad it worked for ya.....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
scarletboa
scarletboa's Avatar
09.19.2009, 12:14 AM
yeah, until the rotor separated from the shaft. that happened one run after i put loctite on the endbell threads, so now i can't get it open.
i can't say anything about the 1400kv L length motor yet, but i hope it works well once i get my EZrun back from nitrorcx.com..
Nixpus
09.19.2009, 04:26 AM
At the moment my savage is powered by a Hobbywing 4465... its way too powerfull for the truck.
Was hoping the KB45-08XL would be easier to controll. However, when I read Scarlets conversion thread it seems like its just as impossible as the 4465 :)
If 25K rpm is the limit for the KB's then the 10XL sounds just about right - 26.600 on 6 cells.
Will a lower KV motor be easier to controll (wheelie/backflip wise) or will the increased torque mean that it wheelies more. I mean if I geared for about 45mph will a 1200KV motor then be easier to handle than a 2000KV? And why?
aqwut
aqwut's Avatar
09.19.2009, 11:09 AM
25K is not the limit, I have ran the 1700KV motor on 8S, and it was insanely fast... I recommend somewhere around the 25K mark.
Example, 1200 KV and 2000 KV motors of the same size.. Powering a Monster Truck...
They both have the same power output.. with the lower KV you have to gear higher and use more voltage, and with the higher KV you'd have to gear lower and use less voltage.
I prefer to use lower KV and higher voltage & less RPMS.. but there is a limit..
Lower KV motors can't take as much amps as the higher KV.. the Lower KV relies more on Voltage.. whereas the Higher KV motors relies on Current. know what I mean?
Nixpus
09.20.2009, 05:48 AM
Yep in order to get the same amount of power (watt) Id have to increase the voltage on a low KV motor, since it have more windings/turns and thus draws less amps.
This also ansvers my question. With the same voltage available the low KV motor should be easier to handle - if geared for the same top speed - since it will have a lower power output. Cheers... KB45-10/11XL here I come :)
sikeston34m
sikeston34m's Avatar
09.20.2009, 07:00 AM
Hi Aqwut,
How about a KB45 10xl in an E Revo?
Let's gear it 20/40 using mod 1 gears, then put in on 6S with a MMM ESC.
How do you think this setup will do, according to your experience with the KB45?
Geared for 44mph according to BG's speed calculator, and spins up to 26,640 rpms.
Also, Where can I find a heatsink/fan for this beast of a motor?
aqwut
aqwut's Avatar
09.20.2009, 08:25 AM
Hi Aqwut,
I think you have a solid (cheap $) setup there man... that should do you really good..... I use a 40mm x 20mm fan, and just zip tie it around the motor... 20/40 gearing comes up to only 36MPH.. for my revo 3.3.. Wouldn't you need 22/36 for 45MPH..?
and that motor is plenty powerful for that revo.. Awesome!
